Here's the story. The motor is a 2002 Bigfoot 60 hp on a 20' pontoon. The prop that came with it was a beat up 14x11 and after a few runs I switched to my backup 14x9. This worked fine except it had a tendency to overrev (above 6100) at WOT. I picked up a new prop last weekend and was talked into a 13.8x11 4 blade Merc aluminum prop. Apparently it is suppose to outperform the 3 blade. With a 1/4 tank of fuel and just me onboard, max RPMs is 5400 at a speed of 19 mph on GPS. What can I expect with 4 onboard and a full tank which would be more the normal? Should I have purchased a 13.8x9 4 blade instead or go back to a 14x11 3 blade?
