I have been thinking about learning how to do my own fiberglass/gel coat repair for some time now. After reading all the how-to guides I can find, almost all of them mentioned the gel coat should be around 15 ~ 20 mil thick, on top of the fiberglass substrate. In the scenario of repairing a gouge penetrating gel coat and the fiberglass substrate, fiberglass material would first need to apply in order to build up the hull material. What is the industry accepted practice to make sure the fiberglass is only build up to exactly 15 ~ 20 mil below the surrounding gel coat level?
I would imagine if the fiberglass is built up to the same level as the surround gel coat, when the new gel coat is applied and wet sanded down to match existing gel coat level, fiberglass would probably show through and ruin the repair job.
Am I over thinking it? Or am I missing some important piece of information in my thought process?
