I just picked up a 57 Johnson 7.5hp motor & 3gl pressure gas tank on craigs list. This little motor is clean, original and runs great. I did notice as I ran it in a tank this past weekend it drips just a little water from the shift lever shaft while running. its runing. Its by no means a major leak at all. Just a drip or so every few seconds.
Is this a major issue ? I reall don't want to tear into. But I will if I should.
Thanks in advance, paul
