tracker 185
jdhgcb
I am trying to find out what the flooring of my 99 tracker 185 is constructed of. I believe the upper front deck is plywood, but how about the rear deck, and the lower flooring. is the lower flooring where the driving seats are aluminum or wood? I have heard it depends on the year. does anyone have any photos of ones you have redone the flooring in that I could use for reference? thanks in advance
Texasmark
Re: tracker 185
Tap on the known surface material deck and then on the unknown. If wood would have a softer tone and firmer to the smack. Match the tones and you are pretty close, realizing the different dimensions and bracing can modify your results.
Mark
