forward thrust hub
proxy
just got a new never on boat 2006 Mercury 25 hp 4 stroke, got a new prop for it, but forward thrust hub that came with the motor is to big for prop the prop size 9.9x13, 10 12, QA3814R. Thanks
JB
Re: forward thrust hub
Hi, proxy.
Welcome to iboats. :)
I think you will get better response if I move this to the prop forum.
jestor68
The prop # you listed is for a "regular" lower unit(not bigfoot). That # corresponds to a 9-7/8 X 13 pitch black diamond prop. Is your motor a "Bigfoot"?
Since Merc and Michigan props generally use the same thrust washer, the Michigan thrust washer # is 16145-2 for that motor with the regular lower unit.
If it was me, I would slide on down to my nearest Mercury dealer and get the correct Mercury thrust washer and/or prop. If the thrust washer fits on the lower unit, but not on the prop, it sounds like you got the wrong prop; i.e., thrust washer too big for the prop sounds like you have a bigfoot and you're trying to put the regular(smaller hub) size prop on it.
