nwboater45
- Sep 6, 2012
- 91
Alright I am still a newbie here with my little project. History: 1989 mercruiser, 3.7, 165, closed cooling with alpha 1 drive. I have an overheating problem that I am trying to figure out. The boat on muffs starts up and idles fine. The temp goes up steady to about 180 to 200 and then I shut it off. I have done a compression check and everything looks fine and no water in the oil. So I went to Autozone tonight and borrowed a cooling system pressure tester. Sprayed the connections and connected to the filler. Then pumped it up to 17 pounds and watched the needle steadly go down. I pumped it up some more to check for leaks. Then I heard water coming out of the water inlet. Pumped some more and then heard water flushing back through the power steering cooler.
OK, the dumb question is, did I do this test correctly? I even read the shop manual at http://boatinfo.no/lib/mercruiser/manuals/mercruiser8.html#/246
The motor should not be running, correct? I understand that is another test.
If I did do the test correctly then why is it back flushing? Did I miss a step?
Thanks.
Thanks.
