Carburetor correct for a 7.4 mercruiser 4 barrel 330HP 1993
erick11s
Hi, I have a engine stock 7.4 year 1993 mercruiser 330HP 4 barrel, need only a carburetor,What is the best carburetor for this engine ? Is for a sport boat with Bravo 3 ( Cobalt 272 1994)...Thanks in advance. see boat pictureDSCF9918.jpg
500dollar744ti
Re: Carburetor correct for a 7.4 mercruiser 4 barrel 330HP 1993
get the carburetor number from the port side of the carb and you can cross-reference with a new or rebuilt carb that's an exact match. should be a 4bbl rochester, not sure of the flow capacity, you will be able to find that out with the engine serial number or the number stamped on the carb.
that's a very nice boat by the way.
Hi, I have a engine stock 7.4 year 1993 mercruiser 330HP 4 barrel, need only a carburetor,What is the best carburetor for this engine ? Is for a sport boat with Bravo 3 ( Cobalt 272 1994)...Thanks in advance. see boat pictureView attachment 167134
Ayuh,.... Post a picture of the motor, not the darn boat,... the intake is even Better...
A '93 shoulda been sportin' the Merc/ Weber, in 750 cfms...
The Edlebrock Performer is a Carbon Copy of the Merc carb,... the parts even interchange,...
Again, the BBC, wants the 750 cfm model...
erick11s
Thanks 500 Dollar, the situation is that the new engine coming without carburetor, not serial only with the manifold mercruiser 4 barrel.
Thanks in advance.
erick11s
Dear Bond, in this moment the boat do not have engine, and i am ready to put a new engine coming without carburetor, not serial only with the manifold mercruiser 4 barrel.The only information I have is: Engine stock 7.4 year 1993 mercruiser 330HP 4 barrel. Please Do you have some suggestion? Thanks in advance:confused:
Ayuh,...
erick11s
Thanks , I was check the edelbrock web page and the model 1410 i think is the best choice, but yesterday mecanic friend told me is better the 1409....1410 or 1409 ????....Thanks again
erick11s
Thanks Howard, Last question.. This carburetor 1410 need some adaptor to install in the original intake manifold mercruiser?
Nope,...
FuelishBehavior
I have a '93 7.4l with a Bravo 1 and I have the factory Weber 4-barrel. However, I'm unsure of the rated CFM's on it but I would assume 650 to 750. But as stated above, the Edelbrock carburetors are the same carburetors. I personally am putting the 1410 on mine during the winter.
04fxdwgi
Webber, Carter, Edlebrock are all basically the same. Just make sure you put on a marine carb, not an automotive / hot rod one. The big determining factor is if the manifold is a spreadbore design (Rochester Quadrabog) or square design (the above mentioned carbs). Most shy away from Holleys on the boats for various reasons.
My '92 is a Webber and from what I read, is a 750 cfm. If you can, get an electric choke model, they seem to work better / last longer than the thermal spring types (though I haven't had many problems with mine).
Ayuh,.... The BBCs got the 750 cfm version, 'n the 4.3l, 'n 5.7l got the 650 cfm versions....
Some of the hybrid 350s, 383s also got the 750 cfm versions...
