which connection puts 07' 3.0 TKS engine into base timing mode?
perna00
I looked online and it says to connect two white wires from the distributor together and bypass the switch. The only issue is that my distributer doesn't have two loose white wires like it says. It does have purple wires disconnected but the manual I read has "white" in bold lettering so I wanted to check with you guys first. Thanks!
Don S
Re: which connection puts 07' 3.0 TKS engine into base timing mode?
The two white wires are on the distributor. There are even pictures in the manual, what manual do you have?
perna00
It was a link to how to set the timing on the 3.0. Just a generic link with the bulletins. I also have the one you linked me for the TKS carb but no info.
