Hi Everyone,
I'm a new member to iboats and this is my first new thread.
I just recently bought a "fixer upper" boat, with a 1981 70hp Evinrude outboard motor. While taking off my lower unit to clean everything and make sure everything was in working order, I noticed that my drive shaft (not sure if that is the actual name of the part, its one of two rods, one is the prop shaft and I believe this is called the drive shaft?) was cracked on the top where the splined area is...I found a gentleman with an 85 70hp evinrude lower unit in great shape with many new parts. I was hoping that this lower unit could fit into my 81 "upper unit". Does anyone know if this will work? I checked some other parts like the prop shaft and that will fit in those year specifications. Any help would be much appreciated. Thank you!
