I am having a stalling problem. The motor runs smooth for 5-10 minutes and then does a slow stall. Also occurs at higher speeds . I have replaced the fuel tank and contents , new primer bulb and hose, spark plugs , had the carb cleaned at the local service shop, cleaned all grounds, and it continues to stall. Compression is at 125 and 130 respectively. any ideas where to look now??
