I recently inheited a 1965 mercury 650 65 HP motor. The motor starts right up with the turn of the key. As of right now the only issue I am having with this motor is it does not want to shift out of forward. I have removed the lower unit to make sure the shift rod is properly attached then put the motor back together and still no luck. I pulled the lower unit back off and attempted to turn the shift rod by hand to switch gears. The rod seem turned clock wise and counter clock wise smoothly without hassle but no matter how much i turned the rod back in forth could I get the propeller to spin freely or go in reverse, Just in forward and ratchet in reverse. Just looking for some advice here, am I missing something or doing something wrong. Thanks.
