margareedaville
- Aug 4, 2012
- 3
Hey guys,
Me and a buddy of mine replaced the water pump impeller and all of the recommended o-rings that came with it the other day on my '05 Sea Ray 180. After putting it all back together, we pumped nearly 2 quarts of new gear lube back in, topped it off in the reservoir but noticed the next day about 1/2 quart of gear lube had leaked out below the lower unit. I looked closer and found that the gear lube is coming out of a notch (see below). This can't be right... Any experience on this?
Thank you so much!
Thank you so much!
