marklhultine
- Sep 1, 2012
- 2
Hi all, my first time here! My 115 is overheating after leaving the dock. It idles fine, and has a great amount of water expelling from the exhaust ports. I can even troll for a bit before the alarm sounds. It is not a false alarm, this I know due to the steam that eventually will start coming out of the exhaust ports. Not a great amount, but obviously this unit is getting hot. I have removed the thermostat, and tested it in hot water. It does activate at about 165 degrees. My mechanic told me to just start changing gaskets until it gets better. Perhaps it is a head gasket, or .,... and I'm getting blow back to push the water back away from the head. Is there a test I can do to find the possible leak? I was told this motor's bottom end was rebuilt, including the water pump. I'm not sure as I have not taken that apart. However, with the amount of water coming out the exhaust, I must believe the pump is functioning as it should. Any ideas out there?
Thanks
Thanks
