Re: 89 force 125 power head removel
For the flywheel you will need a gear puller or a flywheel puller. No special tools for the stator. If this is your first, buy some small zip plastic bags and a permanent marker. bag all bolts and screws separately while labeling each bag. This will make assembly a lot smoother. Some bolts and screws will be rusted, replace them if you can or wire brush 'em and soak in oil until assembly. A manual with disassembly instruction will also be very helpful or at least exploded view.
