In the Mercruiser #14 manual, it states: Rubber gasket must be properly positioned and GLUED in bell housing bore before installing drive unit or water may leak into boat. And coat entire studs and threads with 2-4-C Marine Lubricant with Teflon.
My questions are;
1- What kind of glue can you use? Does it have to be from Merc. or can you get it from an auto parts store?
2- What is the Marine Lube with Teflon, is it like anti-seize, or is it a sealant? Is it necessary?
My questions are;
