  #1
Old September 14th, 2003, 02:57 PM
CCrew CCrew is offline
Default Stripping paint/corrosion from aluminum?
I'm looking for any suggestions on the best way for stripping corrosion and old paint from a bunch of aluminum stern drive pieces. Inclination is to take it all apart, glassbead, prep and paint, but that's going to be a chore. Any "quality" shortcuts from the pro's would be appreciated!Roger
  #2
Old September 15th, 2003, 12:53 PM
tmac58star tmac58star is offline
Default Re: Stripping paint/corrosion from aluminum?
I use a $5 strip the paint off drill/grinder wheel I got at Walmart. Not wire. Some kind of composite material. Cleans things up well, costs very little and doesn't scratch the finish. On the same aisle as the drills.
  #3
Old September 15th, 2003, 01:47 PM
Paul Moir Paul Moir is offline
I'm with the timster. I used chemical strippers before switching to these - they're much better. 3M hard black ones (looks kinda like a sponge) are really fast, but they will chew the aluminum a bit. Mind you that's good for fixing corroded areas. 3M brown flexible ones are slower, but nicer on the aluminum and you can get into corners with them. If your doing a lot, get both.Wear a dust mask. Inhaling zinc chromate is not recommended.
  #4
Old September 15th, 2003, 06:25 PM
Thanks guys for the responses. I'm looking at getting into some nooks and crannies that even a dremel would be hard pressed to maneuver in... Seems that these stripper wheels would be a tad large?Specifically it's all the gimbal/transom hardware.. not like a large area. Thanks again,Roger
  #5
Old September 17th, 2003, 09:21 AM
SBPD1717 SBPD1717 is offline
Using a chemical stripper would be the easiest but what if the sterndrive wasn't disassembled?Would the chemical stripper eat the gaskets? I am looking to repaint my sterndrive because of corrosion but don't want to disassemble it to paint it?
  #6
Old September 17th, 2003, 08:27 PM
DJ DJ is offline
CCrew,If the old p[aint is on there that good, don't remove it. Just make sure it's clean.Wash the bare AL spots with a 50/50 solution of vinegar and water. You can wash the whole thing, it won't hurt the painted areas.Then, apply zinc chromate primer to the bare spots.Finish with a the top coat of your choice.
  #7
Old September 18th, 2003, 12:50 AM
djohns19,Thanks for the response. I guess it may or may not help to make myself a tad clearer. :-)I don't have an issue with the remaining paint, as much as I have an issue with the areas that were bare aluminum and are now pitted, and encrusted with a scaly oxidation. So far, it's even resisted efforts with a wire brush to remove. While I had indeed intended to prime with a zinc oxide etching primer, I'm somewhat averse to painting that over the existing oxidation. Common sense (or maybe lack thereof?) tells me that I need to remove that oxidation prior to the priming. As the third owner the boat was presented as never having been in salt water, to which I can only shake my head seeing what I'm seeing now!Is that the purpose of the vinegar, in that it's acidic and will neutralize the oxidation, or is the vinegar simply used to etch the surface so that the primer will bond better? Were it steel, I'd just have it hot-tanked, but being aluminum, there wouldn't be anything left if I did!
  #8
Old October 24th, 2003, 06:52 AM
ratherbefishin ratherbefishin is offline
While the most common method is mechanical stripping[ wire brush, sanding, sand blasting] chemical stripping is very effective, and much less labour intensive- plus you get it all-tough to do with sanding. Go to www.napierenvironmental.com and take a look at the new generation paint strippers-non toxic,no fumes and won't burn your hands on contact.They are used in the aircraft industry.
  #9
Old October 24th, 2003, 08:56 AM
DJ DJ is offline
CCrew,Nothing beats sanding. I've done several aluminum boats. Check out this thread. http://www.iboats.com/cgi-bin/ubb/ul...;f=26;t=000917 Plus, for sealing seams use Gluv It. Available at: www.westmarine.comIt's simple to work with and does a fantastic job.This was the last one I did. http://mypeoplepc.com/members/djohns19/djohns19/
  #10
Old October 26th, 2003, 04:40 AM
I agree sanding has been the traditional way to remove paint, but it has drawbacks- not the least of which is it is labour intensive, plus the fact that no matter how careful you are, seams, crevices, around fittings, rivets, it is almost impossable to clean the old paint right off.That's exactly why a chemical stripper not only is much less time consuming, it gets those hard to reach spots- exactly where paint failure begins when the old coating has not been properly stripped. If you go with one of the new generation paint strippers, they won't damage gaskets, or other fittings,or harm the substrate be it aluminum orgel coat, plus are totally benign- they don't burn skin, have noxious fumes or are environmentally harmful.Spray or brush it on, wait overnight, and powerwash it off.You are now down to the base substrate, ready to prime and paint.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stripping paint off of aluminum 1959_FDR Boat Restoration and Building 7 June 30th, 2006 12:20 PM
Stripping paint what66 Boat Restoration and Building 6 September 15th, 2004 10:56 AM
Original paint stripping on aluminum??? vgeraci Boat Restoration and Building 0 August 23rd, 2004 10:42 AM
Paint blistering/corrosion-aluminum boat motownbob Boat Topics and Questions (not engine topics) 9 February 14th, 2004 08:11 AM
Stripping Paint bracboy Boat Topics and Questions (not engine topics) 1 November 20th, 2003 05:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
