I replaced the shift cable on my Merc 500. It is a pump unit and the old cable split open. It's on a 19 foot Smokercraft Sled. Both the boat and motor are vintage 1972. When I went to test it in a nearby river the shift lever seems to work fine and the unit will go into forward, neutral and reverse but when I give it throttle in forward it will not get into plane. The motor will rev up to about 3/4 and then will bog down a little. The most I can get out of it for speed is about 8-9 miles an hour. Before the old cable broke the motor had no problem taking the boat 20+ miles per hour and would handle pretty much any river in Oregon. I've searched the Mercury forum but can't find a discussion that helps me know how to diagnose and fix the problem. Any help would be appreciated.
