guys,
i just bought a 1988 25hp two stroke short shaft tiller steering.
there is a zirc grease fitting on the lower shaft of the engine for turning. when i put my grease gun to it, it wont pump anything into it. i took the fitting off, put it in my gun, and it pumps grease thorough it fine. im suspecting that the grease is old and dried up and thats preventing new grease to be pumped in ?
how can i get it to accept new grease ? can i take the zirc fitting off and blow compressed air into it ? or take the zirc fitting off and squirt some wd40 or pb blaster into the port, let it set a few days, then try again ? the steering is kind of stiff, but still useable.
also, it is kind of hard to tilt it up and down. i looked on the shaft that it rotates on, the tilt tube, and there are no zirc fittings, but two little pin style holes. i tried putting grease in the holes with a needle fitting on my grease gun, but it just comes back out at the hole opening, it isnt accepting the grease.
how do i get grease in there ? i can see old grease there, so im sure it has been greased in the past, i just cant figure it out.
can i drill and tap the two hole to accept two zirc fittings ?
thanks for any help you can give me. i really need to free it up so its easier to lift up and down, and steer.
thanks guys
thanks guys
