Q about FlatRate manuals
alexr254
I have a friend who has a small boat/engine repair business here in FL. He has been looking for a industry standard flatrate guide.
I found one from a site called Spader.com. But they are asking nearly $1K for this...
Is that normal? Can anyone help me find something cheaper for him?
Capt Ken
Re: Q about FlatRate manuals
When dealing with saltwater engines, throw any flat rate manual out the window.
Don S
Flat rate manuals are only good if the engine/drive is sitting on the floor. They may give you 30 minutes to replace a raw water pump impeller, but that goes out the window when you have to remove the engine from the boat to get at the pump. Or to replace a starter, of lots of other things.
Flat rate manuals are basically what the manufacturer will pay the dealer to fix the problem. That typically gets adjusted on the fly as well.
alexr254
I would think the Flat Rate guide has that info as well, like time it takes to remove a specific engine, from a specific type of boat, remove any pump or impeller..etc.. Time adds up of course.
Anyway, i dont think its worth paying close to $1k for the flat rate guide from Spader. I was hoping for other solutions besides none.
Thanks
-Alex
Capt Ken
Nope, unlike cars, they have no idea what boat or type of boat the engine is mounted to. They just give a flat amount of time to remove an engine no matter what boat it is in. So if you have to remove an engine from inside a cabin, you get the same as one sitting out in the open on the back deck. Estimating a job comes from experience and best guessing.
