FuelishBehavior
- Aug 7, 2012
- 139
I'm completely baffled with this issue. A quick history. I bought this boat and it ran fine. The coil experienced heat soak and wouldn't run after it got hot so I replaced it along with cap and rotor for good measure. Motor picked up 500 rpms peaking at about 4600 and has run great. Took it out last Friday ran awesome. Flushed motor same night, decided to take it back out on Sunday morning because the fish were biting. Engine will turn over and not start. The motor while turning over would occasionally sound like it was firing but would act like it was too far advanced and stop turning over and would backfire through the carburetor until I would release the key and start again. I just assumed ignition sensor in the distributor and changed it. The problem is still there. I tested the coil and got fire. However it looked "yellow/orange" which to me seems weak. I tested same at #1 plug wire, spark seems "yellow/orange" weak. I did the old fashioned compression check with my finger in the #1 plug to find TDC and checked the rotor. The rotor was 2 wires past the #1 wire. I assume timing chain had slipped. However, the motor must have rolled a little further because as I was removing the harmonic balancer I noticed that the timing marks when set to the pointer at TDC the rotor in the distributor was actually aligned. My bad, I should've just checked here first. I went ahead and verified the timing chain marks lined up, upper gear dot down, lower gear dot up. Chain had a little slack but functional and within parameters. So now what, is it the ignition module? Does the ignition module also act as an amplifier as well? The Mercruiser TBIV ignition test checklist calls something an amplifier? My fuel is fine. Have also checked with starting fluid and get the same result. Does the ignition module control the advance as well and could the module just be malfunctioning and need to be replaced? $250 part that I don't want to change if it's not the culprit.
