3.0ltr mercruiser tilt trim.
denishallinan
i have done my pre season check up and found the trim will not operate. Ran the motor for 10 mins and the trim operated ok if a little slow, when i went to put the boat back in the garage, all that happens is a clicking from the pump. any advise appreciated. thanks
Oshkosh1
Ensign
Re: 3.0ltr mercruiser tilt trim.
Check your battery. Check/clean/tighten/grease ALL connections at the pump.
denishallinan
:)Thanks for your advise Oshkosh1, cleaned all the terminals and trim is working like new..
