Engine Swap
Davebmtx
I just bought a 1991 Four Winns Horizon 200 and the original motor (5.0) 302 was taken out and rebuilt. The motor is not currently in the boat. I was wanting to go with a bigger engine say a (8.2) 502...any ideas or suggestions on attempting the swap? I'm looking for more speed and power. Is it a feasible attempt or not worth the effort?
thumpar
Re: Engine Swap
Unless there is something special about this boat I would put it together and sell it then get the boat you want.
Struc
Re: Engine Swap
Your best bet would be a 383 build. Forget about switching over to a big block. Not worth the effort.
spdracr39
Re: Engine Swap
Not sure what outdrive you have but be sure to check the max HP rating of the hull and outdrive before going to wild.
series60
Re: Engine Swap
I'll look into my crystal ball to see if I can tell what outdrive and engine you have. Is it a Ford[302] or Chevy[305], Mercruiser, OMC, Cobra outdrive? I'd be more interested in the shape of the stringers and transom of a 20+ year old boat before considering re-powering. Will the weight difference between a small block and big block shift the cg after too much. Could the upgrade overpower to drive?
How much money do you want to spend to add 5-8mph to the boat? As mentioned a 383 would be your best bet if your current engine is a sbc.
Davebmtx
Re: Engine Swap
Ok I just had access to a Merc 502 and outdrive set-up but it sound like is more trouble than what I will get out of it. I do have a 400 SBC that I may use for the swap. I've heard both good and bad about the 400 but more good than bad....I am looking to get about 55-60 mph or am I asking for to much out of this boat. It's a project boat that I picked up for $500 so any ideas good or bad will be helpful.
Re: Engine Swap
Mercruiser didn't use a Ford engine since the late '70's. Are you sure it's a 302? The distributor is in the front of the engine or back?
series60
Re: Engine Swap
The big issue with sbc400 are the very small steam holes in the block/heads. The small holes can plug up very easy with an open cooling system. All the sand and debris along with a little rust can plug these holes causing a hot running engine.
