Hello,
So I picked up a boat for a cheap price and it came with a well used 1989 Evinrude 25HP outboard with long shaft. The motor had been sitting for a while so I had a mechanic replace the impeller and leg oil. The motor fired right up and was pushing lots of water.
I took the boat to the lake for the first time and everything went well for about 15 minutes. We went through all of the RPM's and the motor ran perfectly.
All of a sudden the motor lost thrust and started to rev up. When I throttled down everything seemed fine so we kept going. We throttled up again and after a few seconds it happened again. I turned around and noticed that there was now no water coming out of the tell tale so I shut the motor off. It was hot so we let it sit for 5 minutes. I checked over the intake grate on the leg and there was nothing clogging the intake.
We fired the motor up again and still no water. We shut it down and paddled home.
I took the water line apart today and there is nothing clogging the tell tale.
The symptoms were like a clutch slipping in a car. The motor rev'd quite high but when I throttled down the motor was still in gear. Is that a common symptom of overheating? I am worried about the bottom end (gearcase) but there was no grinding or vibrating, nothing.
Think the brand new impeller failed?? What else could stop the water from flowing? Any thoughts??
Thanks!
Thanks!
