kelpkritter
- Sep 2, 2012
- 2
I have replaced the ignition switch on my 1997 Mariner 115 but cannot get the motor to fire.
I initially changed the switch because I could not trace the reason why I was not getting power at the switch. It turns out the yellow/red wire at the starter solenoid was not getting a good connection. Reworking that connection would have solved the problem right there but I had already started re-wiring the switch after overlooking this problem. At the time I was using the original wiring harness from a previously installed 1986 90 HP Mercury which had no issues until the loose wire got me to changing out the ignition switch. During the troubleshooting I also tried plugging in the wire harness from the Mariner which also had the temp alarm attached and everything seemed ready to go to re-wire the new switch to this harness to get use from the temp alarm which I did not previously have. I got everything hooked up to the new switch exactly as it was wired to the previous switch and two things changed. First, the alarm did not sound when the ignition was turned on and the more pressing issue is the starter motor runs but the motor makes no effort to fire.
Frustrated, I have used both harnesses now and still get the same results. Any ideas why the motor is not want to turn over even though the starter motor is engaging?
This was hard to condense and make somewhat understandable after working on the problem for the past few days, please feel free to ask any questions to help narrow the steps I have been taking.
Thanks for the help.
