78 cobalt merc260 won't crank
bharman12
merc 260 will not turn over i have replaced battry,battery cables, and celiniod. <br />starter engages but won't turn.
bomar76
Re: 78 cobalt merc260 won't crank
So....starter engages the flywheel, but won't spin engine?<br />Engine cylinder (s) full of water would be one culprit.<br />Locked up outdrive would do it too, among other things.<br />Have you attempted to turn engine over by hand?<br />I would guess not.<br />Pull spark plugs- look at each one....any of them rusty?...if so, cylinder is full of water.. ground coil wire, try to crank, if it does.... see if it blows water out of the cylinders....if it doesn't crank, pull drive and try to crank....if it does, drive is locked up....if it doesn't...engine is locked up.
bharman12
ew had bat out 4month's ago ran great. checked oil no foam. if it's the engine or drive that would suck.thanks for the ideas i'll drop a line about the out come.
