Re: Vacum Gauge
You actually CAN minipulate mixture to reach the highest MP if needed.
apologies to the OP. This is sort of off subject........... but, I must respectfully disagree. No pilots operating handbook, and Neither Lycoming, Continental or Franklin ever suggested adjusting mixture to control manifold pressure. Manifold pressure is only regulated by carburetor butterfly valve position, (MSL) altitude and temp (AKA density altitude) ....... manifold pressure might change with RPM a little but it would be an inverse relationship.
I.E. If you were running rich at a non-full throttle (open butterfly) power setting, leaning the engine to best power would actually increase RPM slightly (with a fixed pitch prop) . The increased RPM would then result in a slightly
lower manifold pressure because the engine would be moving more air through it at that previously fixed (or even FULL open) throttle setting. In a turbocharged engine the MP might increase slightly if you lean the engine to best power because the increased power will produce hotter higher pressure exhaust gases to the exhaust turbine.....but we're talking about N/A engines.....
I have only flown carbureted, fuel injected, turbocharged and non-turbocharged aircraft since the 1970's. The airplane I have owned since 1981 has a 180 hp engine with a Hartzell constant speed prop. It also (of course) has a manifold pressure gage. Mixture adjustment from full-rich to either max power or the best economy setting, doesn't change the manifold pressure at all.. Maybe there's an engine out there that operates like you're saying but I haven't seen it.......
