New 4 cyl GM crate motor going in 1996 Alpha One Gen 2
EXCEL21SL
Hey guys, I Just bought a new 3.O GM marine crate motor. The motor doesn't just bolt in like I was told. It came with a 14 in flywheel vs a 12 3/4. I know I should of done the research beforehand but here I am. I bought a 14 in flywheel coupler and put the bellhousing on and now the starter won't fit. It turns out I have the straight bolt pattern and I think I need the staggard bolt pattern starter and the bellhousing bolts up but' will it actually work if I buy the new starter? Has anyone been through this before?
Re: New 4 cyl GM crate motor going in 1996 Alpha One Gen 2
Ayuh,.... Is the block drilled for the staggered bolt pattern starter,..??
If so,... ya it oughta work...
EXCEL21SL
it looks like its drilled for both but, that flywheel cover only has about an 1/8 inch clearance all the way around. I guess since the crate motor is supposed to be adaptable to multiple generations that would make sense.Keyword (guess). Thanks
Ayuh,.... If it clears,... it Clears....
