1983 90HP No Start
rjserson
My 1983 90hp Johnson ran fine yesterday. Today I turned the key and nothing, no click, no nothing. The battery is new, about 1 hour use. I checked the ground, ok. How can I check to see if the ignition switch is ok or if some interlock or kill switch is not right? Any other suggestions?
TrueNorthist
Re: 1983 90HP No Start
Did you check the positve connection too? Do any of the electrics work? (Lights etc) Are you sure the battery connections are spotless?
Will Bark
Did you check the fuse under the cowl located close to the starter solenoid?
