  #1
Old August 10th, 2003, 09:51 PM
MartinR MartinR is offline
Default Installing floor in aluminum boat
Hi. Just bought my 1st boat. A 14ft aluminum with a 1958,18 hp motor. It runs great. Anyways I was thinking about puting a floor in it. There are 3 benches, is it possible to take out 1 or 2 of them, or will this weeken the hull too much? Also what kind of support do I need under the floor? Thanks.
  #2
Old August 10th, 2003, 10:00 PM
DJ DJ is offline
Default Re: Installing floor in aluminum boat
Martin,I wouldn't. You can, however, probably cut out a passageway though the middle of them as long as you tie the two halves together at the bottom (floor).
  #3
Old August 11th, 2003, 05:27 AM
catfish1 catfish1 is offline
i'm going to assume this is a jon boat! martin the benches support the sides of the boat, they also provide a space for the floatation foam. so it wouldnt be advisable to remove the benches.
  #4
Old August 11th, 2003, 05:47 AM
CharlesW CharlesW is offline
Location: Ankeny, Iowa, Sun Valley Lake, Iowa whenever possible:)
Some 15 years ago, my son put a floor in an old Starcraft V-hull aluminum boat with no problems. We still use the boat with the same floor, although the carpet has had to be replaced two or three times.The boat is 75 miles away so I can't look at it right now, but...., I seem to remember that he installed some "U" channels across the bottom area of the boat. There was some sort of reinforcement in that area, but I don't remember just how it was made. He then screwed 5/8" treated plywood to those channels. He cut and placed pieces of styrofoam under the plywood before screwing it down. He installed three seat pedestal sockets and used three seats for the main seating. One of the original bench seats was left in at the bow. It is nothing but a board that bolts into a clamp riveted to the sides of the boat. It has been used a lot of hours with both a 10 HP and a 25 HP tiller steer motor. Obviously what worked for us, may or may not work for you. It seems like every boat is built just a little different. It definitely made the boat a whole lot easier to move around in. Charles
  #5
Old August 13th, 2003, 12:54 PM
Thanks for the info. I think I'll hold off for now.
  #6
Old August 17th, 2003, 07:16 PM
bayman bayman is offline
I haven't done this but I have heard that some people like putting in this infopop.com ]Starboard[/url] lumber material as a floor in aluminum boats. It's supposed to last a lot longer than plywood and you don't have to worry about treating it etc... If done right it helps make aluminum boats quieter too.- bayman
  #7
Old August 29th, 2003, 09:27 PM
gdbwinnipeg gdbwinnipeg is offline
We had an old 16 ft aluminum boat with three bench seats in it, which housed the foam flotation blocks. I used 3/4 " plywood to make fitted floor panels between the seats. The edges oof the floor were cut so that they rested on the ribs that ran across the inside botoom of the boat. To give support to the middle of the floor I pop riveted "L" shaped clips to the aluminum upright faces of the seat supports. They were positioned so the underside of the plywood was supported by the lower part of the "L". It's a bit hard to explain, hope you get the idea. If you want to e mail me I can reply with a bit of a drawing of what I did. It worked really well and you can take the floor out easily if you want to clean it out. Good luck gbryson@autobahn.mb.ca
  #8
Old September 13th, 2003, 12:29 PM
bassin large bassin large is offline
I built a casting deck on my 12' fiberglass Sears Gamefisher. Check it out: http://hometown.aol.com/brideg19/Bas...onversion.html
  #9
Old September 13th, 2003, 07:36 PM
pbailey pbailey is offline
How much weight did that add to your gamefisher??pbailey
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Floor for 16' Aluminum boat edandq Boat Topics and Questions (not engine topics) 14 June 5th, 2009 09:12 AM
Floor in Aluminum Boat jd438 Boat Restoration and Building 2 April 20th, 2006 04:54 AM
Aluminum Boat Floor Replacement turtle1173 Boat Restoration and Building 16 November 20th, 2005 07:55 AM
Question about installing floor in alum boat MartinR Boat Topics and Questions (not engine topics) 2 August 13th, 2003 12:56 PM
aluminum boat floor.... longshot Boat Topics and Questions (not engine topics) 1 October 1st, 2002 07:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
