90hp johnson
jcwinck
i have a 1986 90hp johnson motor and i cant seem to get it to run and idle like normal and i was told it needed to have the carbs cleaned any suggestions is that a hard task
McGR
Re: 90hp johnson
Cleaning the carbs on a two cycle outboard means removing the carbs and disassembling them, completely cleaning inside and out, then reassembling. Usually, it is best to rebuild the carbs while you are at it, kits aren't too expensive.
On that motor it is not a very difficult task, just pay attention to how things came apart and be sure to put them back that way. Most folks with a reasonable amount of mechanical aptitude should be able to pull off a carb rebuild.
boobie
Re: 90hp johnson
Before you work on the carbs, do a compression and spark test. Spark should jump a 7/16 " open air gap on a tester.
AEROCOOK
Master Chief Petty Officer
Re: 90hp johnson
Since you're not familliar with the job, I suggest doing 1 at a time, that way if you cant remember how somthing goes back together you will have the other for reference.
boobie
Re: 90hp johnson
It may not hurt to also get a service manual either.
