No! Wrong direction for hole shot. Now I am back to checking that tach, and also verify speed with GPS. I would NOT go up in pitch if she struggles to plane. Clean up the 19 you have, retest with accurate tach and GPS speed (phone app is fine). We have to start with an accurate baseline. Good luck!
Do you know how to use your trim to assist planing and then top speed?
When you trim too high, the rpm goes up and the speed goes down. You want highest speed and highest rpm at the same time.
