Just cleaned lower carburator on 1984 3 cyl 75 hp evinrude, replacing float & the valve assy. I understand that you should be able to blow thru it when held one way and not blow thru it upside down. Question is when blowing thru it: should it be an easy air flow - like blowing thru a straw or should it take some umpf? (I'm thinking pretty small passages so should take some umpf...right?)
Tom B.
Tom B.
