I have a smooth running 1981 Mercruiser 470 that runs cool and has good pressure on all cylinders as well as oil. The last 2 trips out I've had a strange intermittent screeching sound coming from the motor when I hit 3000 rpm and above. Alternator belt looks good and I haven't confirmed the alt bearing yet. I did just have a new Mallory E-Spark electronic ignition installed and the mechanic had to mess around with the distributor to install a mounting plate. Do distributors make a noise if not installed properly? My voltage is steady with no fluctuations. And as I said the motor performs beautifully except for this awful new noise. Any input would be much appreciated.
Cheers!
Cheers!
