Re: NEED HELP ABOUT 3.7 Mercruiser?
Howdy,
Welcome aboard!
Well, it would have been "better" to have asked the question before you bought it. Then most of us would have told you to run away from it! (the obsolete 3.7L engine!)
If you didn't damage the engine by blowing the head gasket etc, that may already be the problem......... You also might have a riser or riser gasket leak that is allowing the coolant to leak overboard or a leaking heat exchanger.
You'll just have to troubleshoot the entire cooling system to find it.
Once you 'fix' it, The 3.7L actually a pretty good running engine. They do have their own unique problems though.................
Stand by. The 3.7L "crowd" will be by in a moment!
You can certainly replace the entire engine either with a long-block or rebuilt engine if required. It may be an easy fix though.
Also, you can replace the engine with a different one (V-6/V-8) but you'll have to replace the drive too. yours is the wrong ratio for either.
AND it won't be cheap. Might be better to just sell it quick and put your money into a boat that is set up the way you want.
Good luck!
Rick
