I let some gas go bad in my tank, but have since cleaned the tank and hose, replaced bulb but continue to have same problem. Motor starts fine, idles well, but when I power up to 3000 rpm, runs very rough. Here's the vexing part, only runs rough for about 5-10 minutes. I pull back on throttle, push forward slowly, and after this time, motor then runs fine for the rest of the day. this has happened the last 10 times I used the boat. I have run Seafoam through with the gas, and have srayed carb cleaner into the intake while running.
the only other clue is when I spray the carb cleaner into the middle carb, it almost immediately chokes out the motor, but when I spray it into the top and bottom carb, it runs slightly higher rpm, as you would expect.
I may just pull the carbs, but if they're clogged, why would it run fine after 5 minutes?
