JonnyPartTime
- May 26, 2012
- 18
Hi all,
I have a 2000 Yammy F15ESHY that I have finally gotten back up and running. It's been performing well with no hesitation, sputters, etc. However, in WOT, I've noticed a "pinging" noise that actually causes the engine to move, like if you were standing next to it and gave it a little "bump" to the side in one direction. It's not consistent, just more of an erratic ping that only occurs at WOT. If I back just slightly off, it goes away. Also, there seems to be a faint rattle, but I can't tell if it's related or if it's truly a rattle. So my question is; would a compression test be a good indicator of a knock or rattle if the compression is off or is there another way to go about this? Also, I used Champion plugs instead of the NGK's because they were the only ones available for purchase at the time that I needed them. Could they be the culprit?? Like I said, fine in every other throttle position except WOT. Thanks in advance!
