We have a 8'x24' pontoon. We had some work done recently and the shop burned the carpet in a couple places. Since they are going to pay for the carpet to be replaced, I figured we should probably go ahead and replace the deck at the same time. Taking that one step further, I thought that we could increase the width from 8 feet to 8.5 feet.
Questions:
1) I do have some adjustment in my bunk trailer, but not enough to move the pontoons 6 more inches apart. Do 8.5 foot wide decks just hang over the toons more than 8 foot pontoons? In other words, should I just plan on the pontoons staying the same distance apart as they are now with the 8 foot deck?
2) Will adding a 3rd pontoon change the answer for (1)?
3) Should I plan on using the same metal support beams?
4) The bimini frame, front gate and middle back part of the enclosure will all need to be replaced/adjusted. Recommendations for sources for these items or do you recommend having something custom made?
5) Recommendations for sources for aluminum sheets that make up the enclosure. The current enclosure has some dents.
6) At a minimum, I may want to replace the decal designs on the enclosure. Sources for these?
7) Aluminum vs wood for the deck?
8) Thinking about marine vinyl instead of carpeting. Recommendations on best marine vinyl? Also wondering if you need to wrap it around the edges, because what I am finding online is 8'6" wide, so with a 8'6" deck, there wouldn't be any to wrap around?
Thanks for your feedback.
Questions:
