tonynoriega2
- Jun 26, 2012
- 114
Hi all..
Took the cowl hood off my motor last night, and to do so, I had to unscrew two adjustment dials (sorry I dont recall what they were).
However, one of them I believe was a low gear fuel adjustment dial. This dial has a set twist radius (from left to right) that is determined by an odd shaped piece.
Which if you slightly push down, only then can you unscrew the dial completely to remove the dial.
I think this piece on mine is slightly bent...and wanted to confirm.
On the top, is how my part is shaped...
On the bottom is how I believe it should be shaped.
And since I do not have a manual yet, would anyone have insight into this?
thx
thx
