140 Evinrude
George1110
I have what I believe to be, a 1987 140 Evinrude. Does this year have the S.L.O.W. program? Is there a way to tell if S.L.O.W. has been installed?
Dhadley
Re: 140 Evinrude
The SLOW feature was in the 1988 and newer models. The model number will tell you what year the motor is. The 87 & earlier motors had a single small power pack mounted on the top of the block towards the port side, the 88 & newer motors had a larger pack mounted in the center of the top of the block. If you look on a parts diagram you can tell which ignition system you have.
