happysteve
- May 15, 2012
- 5
1985 merc 75hp 2stroke, 4cyl. serial A169314
Lower end won't drop. I have the service manual and a mechanic helping me. searched you tube, iboats, and even justanswers.com mechanic couldn't help so far. I bought this Proline 16' w/75hp Merc a couple months ago. It had been moored in salt water. the motor wouldn't start. replaced starter and cleaned carbs. It ran for an hour then motor bog to a complete stop, limp home idle only. Replaced fuel pump, fuel lines, fuel tank, fuel. Not fixed. ran 3 min., motor bog to completer stop, limp home. Motor would pee, but never very strong stream. Learned that worn out impeller may cause motor bog. (As well as stator)
Attempted to remove lower unit. removed 3 bolts forward and 4 bolts aft including anode. This model does not have a shift shaft nut to remove. I don't think there is anything to disconnect on the shift shaft? Or is there? Pry'd the lower unit down enough to get a putty knife, then 2 screw drivers, then barely the end of a crow bar. and still only an eighth inch gap, daylight all the way through. Then wedged chisels between forward stud nuts and cranked on nuts to force the lower unit downward, nothing advanced, still barely an eighth inch gap. what am I missing?
Have read that the drive shaft splines may be rusted to power head? If so, how the heck do you get it loose? Drive wood wedges a little more each day? & Hammer down on the torpedo? Can you get to drive shaft from the power head? & hit it down? Remove carbs? and access drive shaft with PB Blaster?... If someone has successfully removed a frozen lower unit, please help. Thank you, and God Bless!
