bilge help
southkogs
Re: bilge help
Welcome aboard: I'm gonna' guess (without knowing exactly what it looks like) you need to get down under the splash well where you can get your hand all the way back to the transom of the boat. The bilge pump typically sits as far back, and as close to the keel as possible (without blocking the drain hole. There's typically a (roughly) 8" x 8" area of the floor that goes down into the bilge back there.
louiefl
Re: bilge help
I learned all sorts of cool stuff about what is under the sole of my boat by sticking a digital camera through my deck plates and snapping pictures in various orientations. Not sure how much room you have, I would start there. Make sure your bilge is well vented, there are no gas fumes, and your flash is on.
markrarend
Re: bilge help
Thank You kind people ,but please note GET TO I know where I just dont know how to get to it
series60
Re: bilge help
Can you see the bilge hose? Maybe you can pull on the hose to remove the pump from under the engine. That is if it is not mounted permanently.
southkogs
Re: bilge help
Got a picture of the back of the boat? If it's enclosed there is typically an access panel.
