Hi
Finally after rebuilding the transom of the boat I bought in Feb this year I have the engine bolted on at last.
I need to now create the wiring but am a little unsure what's needed in terms of wiring to the console.
I have 4 gauges -
Honda Tacho (analog)
Honda trim/tilt (analog)
Faria Volt meter
Unbranded Fuel gauge
The fuel gauge of course has its own separate sender so I can forget that for now
There is a spur of wires that comes off the harness from the ignition/throttle control box and it has these wires:
Not sure what each one is, but I'm led to believe that the wiring harness has wires to provide signal & power for gauges.
Can anyone possibly clarify what each wires is in the pic above please?
Aside from the gauges themselves, I have various other things to run, so it would be really useful to know what current the feed through these wires is able to supply. That way I can determine what other items can be powered from this without the need for sending more wiring from the battery to the switch panel.
This includes things like fish finder/gps, vhf radio, nav lights, bilge pump (I'm certain this will definitely need a beefier power source, even if the other things don't!).
Somehow I can't envisage these items plus gauges and their illumination all coming from these little wires.
On another cabling related note, can anyone advise what the standard gauge/thickness/cross section (mm2) is that's needed as a minimum for the engine supply cabling? Ie the cable that goes from battery to engine?
I'm fitting an isolater key and a rotary switch for battery selection so I need to make up a series of short cables for this and am uncertain what cable I need optimally for this. Last thing I want to do is create problems by installing cables that aren't up to the job, so at least if I know what the minimum spec is then I can set that as a baseline for what to buy.
Many thanks!
Jim
I have 4 gauges -
Faria Volt meter
Many thanks!
Jim
