BOWTECH.JUSTICE
- Aug 26, 2012
- 170
1992, 4.3 Mercruiser. I see many threads on here about problems with power steering hoses blowing out at the cooler. I too have this problem and can't seem to figure it out. Have changed the pump after it went dry and ruined the bearings, thought it was fixed and after getting it back running, the hose that enters the cooler blows out right at the fitting on the cooler. I now have the hose and cooler out and hose is still a good hose and I see nothing wrong with the cooler. I can blow air though it with no problem. This is the low pressure end so how does it build up so much to blow the hose out and what can be causing the blockage?
