bluebrownie
- Feb 19, 2008
- 201
just bought a used 25 hp... 1993...it sat for 5 years unstarted...when ilooked at it, i did a compression test and had 125 in each cylinder. I then put 2 new plugs in and motor started right up on first pull. i also shifted it in gear in the barrel...shifted no problem and prop engaged... am i to assume that the motor is not cooked at all? is that a safe assumption? i changed water pump too, but not getting water thru telltale... but i want to make sure i am ok with the cylinders...so would the fact that if fired right up rule out the head being cooked...no paint peeling signs either...
THANKS ALL
THANKS ALL
