Four winns vibration at low speeds
ctklinck
I have an 89 four winns 200 horizon, a mechanic pulled the motor to fix a leak on the exhaust pipe. He didn't pull the outdrive. Is it fairly easy to lign up the motor when putting it back in? Because now Im noticing vibration especially at low speeds. Im afraid he didn't lign up the motor correctly when he put the motor back in? Since he didn't pull the outdrive is it a no brainer to drop the motor back in and it be aligned properly? Is there a way you can look at it and tell if its aligned correctly with out pulling the motor again?
