Re: This sound like a carb problem
I would suggest that you get the FACTORY manual, you're gonna need it if you are going to maintain your engine anyways.
Read the section on overhauling the carbs, if you think it's something you can handle, go for it.
It sounds a lot harder than is actually is, with directions you can probably do it.
