Size prop for 40 HP
spock4444
I broke me prop#$%^. I was wondering what sizes and pitch I could use other than the stock 11 3/4 X 17 ?
Thanks Rick
kenmyfam
Re: Size prop for 40 HP
Lots of variations in props. Nobody can recommend anything without knowing what motor, what boat you are trying to push with it, current performance before the prop broke and your WOT RPM.
Suggest also that you put this in the props section of the forum.
Welcome to iboats.
steelespike
Thanks Rick
Welcome, If you answer the Qs in the sticky at the top of the prop forum we can tell better what you need.
Texasmark
Is that what you had? Were you satisfied with it? If so, why ask the question?
