2003 Yamaha 115 4 stroke stalls
seapro21
My 2003 Yamaha 115 4 stroke has 533 hours, starts and runs great but stalls regularly when coming back to idle speed and always stalls when passing through neutral when changing gears. Changed fuel filter and installed new fuel/water separator(no water but dirty fuel in old separator) and just ran for 1/2 hour with same problems! Any ideas?
schematic
Re: 2003 Yamaha 115 4 stroke stalls
-ISC motor
-dirty injectors
-low fuel rail pressure
-leaking fuel pressure regulator
1nebel0
Have your injectors cleaned and flowed every couple of years...Easy to do and the best money spent....
Capt Ken
You have a faulty/dirty IAC (idle air controler) or intake pressure sensor. Located on the port top of the engine just under the shroud. You really need to have it connected to the Yamaha diagnostic system and have the voltages read on these and other items.
