Re: No power under load Yamaha F40 outboard 4 stroke
I did have the carbs apart and I did clean them with the canned stuff, Berryman's. It runs a little better, but not great. It sure seemed like the accelerator pumps were working okay, but maybe not. I do wonder if the solenoid on the top carburetor is for more than just cold start enrichment. Does anyone know how the solenoid and plunger are supposed to work? If I put 12 volts to it, it does nothing. Both wires going to it are the same, yellow with a black tracer stripe. When the engine is running it gets warm even though the key is not pushed in for the "choke". I'm wondering if it has anything to do with acceleration enrichment as well as cold start enrichment. Apparently this solenoid on the top carburetor is called the "prime start assembly". Since it does nothing when I put 12.6 volts to it, I'm very tempted to replace it, but it is a $253.00 part. I cannot find any info on it with various internet searches.
When I cleaned the carburetors they really did not appear to need it, but I did it anyway and it does seem a bit better.
Thank you for the suggestions so far. I would really like to know more about the prime start assembly.
