barefiel76
- May 11, 2012
- 12
Please bear with me while I explain all the details. So I have been working on restoring a 1984 4 Winns Catalina since about April. When I got the "free" boat it had sat outside for about 5 years. I started with replacing the entire interior from the fiberglass floor up. At that time I thought the motor ran fine. I hooked it up to a battery and after a few minutes it fired up. So I left it alone while I worked on appearance.
The first time we took it out to the lake it ran for about 8-10 mins. no problems. I put it in neutral for about 30 seconds started to accelerate and the engine made a bogging down noise and stalled. I got it restarted ran fine in neutral, put it in drive and it bogged down and stalled. That was it for the day. Wouldn't start after that.
I brought it home, replaced all the fuel, replaced all the spark plugs, cleaned out the fuel filter and sprayed out the carbs with carb cleaner. It ran in the driveway, but the throttle had to be push up to get it started. It acts like it is not getting enough fuel. After running for a few minutes it warms up and can be taken back to neutral and runs fine.
We take it back to the lake. Boat starts, put it in drive and it stalls. Repeat a few times, same result. Boat stalls under load.
Come home and I rebuild both carbs. Boat runs in drive, but still have to throttle up to start and in neutral acts like not enough fuel. I noticed last night that one of the wires from the stator to the switcher board is destroyed. Rotted away to dust.
Can that have anything to do with the engine problem? I am open to ideas and at a bit of a loss. This is my last effort before I have to take it somewhere or call it quits for the season. Please help, I will be very grateful.
